It can be downloaded here:Show it
So, in looking at one of your YT vids, your mask detection software appears to have a minimum of a 40% false negative failure. Out of 5 people in the video that the software detected, 2 of them were compliant and had masks on, but the software shows them as not compliant. Care to explain how this would be acceptable?
[/QUOTE
"TURN ORDINARY CAMERAS
TO A RING,NEST,ARLO,WYZE USING
AN ARTIFICIAL INTELLIGENCE SOFTWARE"
Just to ask, why would I want to down-grade my cams?
I get your point. This particular software main point is it's ai people detection. It had been trained to detect people at high accuracy thus reducing false positives.The main idea was to connect it to an existing camera which gives alot of false positives."TURN ORDINARY CAMERAS
I did watch them and I did notice in several other clips, the AI at times, was having issues distinguishing between masks and no masks. As far as the software, I run OSX, so I don't believe you have a version that will run on Macs. One of the PC guys should be able to help you with that.I get your point. This particular software main point is it's ai people detection. It had been trained to detect people at high accuracy thus reducing false positives.The main idea was to connect it to an existing camera which gives alot of false positives.
I will be happy if you can give me a feedback on what you think about the software.
Thank you
