- Mar 27, 2015
- 134
- 4
try bothits deleted.....re adding got ip user and password....should i do the find/inspect? or dropdown?
see sticky in trouble shoot section on adding cams that are not listed...try suggestions..you are doing something wrong...i re added camera ....still the same
install an older update...search forum for file..I really think Something happened with either BI or windows 10 update....I blamed it on camera so a replaced it with same oem.....same problem....camera been working for several several months without issues
okay I will try again and go thru sticky......I Agree that i must be doing something wrong but have not got it figured out-seems easy - this is probably my 50th camera addsee sticky in trouble shoot section on adding cams that are not listed...try suggestions..you are doing something wrong...
