IAmATeaf
@IAmATeaf The "key" (iframe) rates on the Reolink cameras are showing as low as .25 with a high of .5 while the, I'm guessing, Dahuas are all showing 1.
Doesn’t that just mean that the Reolink is skimping on iframes to presumably reduce the size of the resultant output file/stream.
Didn’t think that that equates to a lowering of the overall frame rate, having typed that I have previously seem similar output pictures where the actual frame rate was dropping way below what was set on the cam with BI showing the frame rate as lower than that set.
