Hi, I am doing some License Plate capturing and using these settings below for Huisan PTZ 10x camera...
Set the Image / Exposure settings to Shutter Priority, Shutter 1/425, Exposure Bias On: Comp Level 50, Cain Limit 50.
Image / Focus to Manual, Min Focus Distance to INFINITE.
Manual focus the camera to the the general distance of where license plates will be.
I am getting a pretty good image of plates at close to 100 feet using camera IR and I also have an IR flood, but it is pointed about 45 degrees away from plate pickup point. I seem to have a ghosting effect that I would like to fix if I can. The fps are 20 and set to 1920x1080. System seems Ok handling this. I did notice with the settings above, my bit-rate fluctuated quite a bit, but it seems OK now considering the view is dark until a plate crosses the screen. Anyway, here is an image of what I am asking about.
You can notice the image has a weak double exposure. This is also a moving vehicle going maybe 20-25mph when taken.
