- Mar 27, 2018
- 7
- 0
In simple view, on the local box or from another box on LAN (via web port 81).
I experience a 1min+lag
If I open the same cams on the BI box, I get almost no lag.
I have a Qsee NVR connected to the same network switch as the BI box, almost no lag
speedtest.net on the bi box shows 188kbps down and 880kbps up
BI shows CPU 45-50 % Ram 4GB
Box has 16gb ram
BI shows totals for bandwidth 312 MP/s
Box connected via gigabit ethernet.
Cams are Qsee 4mp
If i disable all cams and enable them back one at a time, at first no lag but after 5 min, lag is there again
Box has 16gb ram
Cams are Qsee 4mp
