Hello,
Sorry for the delay i wasn't available to work on my PT cam.
Here's the result, now i can run curl command without any problem, i suceeded to reboot my cam with curl command : curl -X PUT "http://userassword@IP
ort/System/reboot"
But i still can't control my cam by curl after http request viewing (when i press arrow to move the cam on hikvision interface) i can see url is /ISAPI/PTZCtrl/channels/1/continuous with an xml file : <PTZData><pan>-100</pan><tilt>0</tilt></PTZData> (when i move to the left)
But how to write it to do it myself ? I don't know how to insert the xml part on the command
Thanks for your help
EDIT : fount it !!!! curl -X PUT -T TEST_PTZ.xml http://login:password@ip/PTZCtrl/channels/1/Continuous (in TEST_PTZ.xml : <PTZData><pan>-100</pan><tilt>0</tilt></PTZData>)
thanks for everything, hope it can help somebody too
Can you please help me to get complete link for pan,tilt, zoom or Preset -:
IP - 192.168.1.20 / Username - admin/ Password - admin
My project got stuck because of this. It will be helpfull if you can support me on this.
Warm Regards,
Saurabh Thakar
