Try contacting your supplier and asking if they can provide you with the technical advisory bulletins.I have also tried the auto enrolment method but yet none of the zones are showing up even though it had said enrolled and I had confirmed the zone expander aswell.
They may want consider skipping straight to the Qolsys IQ Pro, which is basically a merger of the Neo and IQ with a built in communicator and easier installation. Not sure how the panel cost compares exactly, but they should absolutely try an IQ Pro.I help a small company do alm wiring that has used the DSC legacy systems. The NEO is what they're starting to use.
Are you installing the zone expander in the main panel or in a remote location? How many keypads are in the system?I have followed all the steps from enrolling the zone expander by putting it the serial number and then going to confirm the zone expander. Yet still it does not show any of the zones.
Can they accept different cellular communicators? Alm.com great but some of the small companies i work with don't always use Alm.com.They may want consider skipping straight to the Qolsys IQ Pro, which is basically a merger of the Neo and IQ with a built in communicator and easier installation. Not sure how the panel cost compares exactly, but they should absolutely try an IQ Pro.
IQ PRO – IQ
qolsys.com
That isn't 100% clear to me, but I don't think so. This is due to the encrypted bus (also on neo) and the removal or the phone dialer which can be used for dialer capture on other communicators. It's unfortunate as 4G will be sunset some time after 2030.Can they accept different cellular communicators? Alm.com great but some of the small companies i work with don't always use Alm.com.
One thing you could try: hook the keypad to short wires directly at the control panel, disconnect in-wall keypad wiring.No it is in the main panel and i only have one keypad
