hi
looking to get BI setup in a property i'm moving into, i was considering using my unraid server with window 10 running as a VM.
Problem is I can't get windows 10 for less than circa £150, so after reading some threads on here it got me thinking, i'm probably best off buying a standalone system, which is cheaper and less like to break than a VM on unraid.
Would the above spec be sufficient to run 4-6 cameras? i'd use it exclusively as a BI server so no other workload.
the model i've been looking at is in the link below, comes with windows 8.1 and official licence, can i get a free upgrade to windows 10 still? or should i be looking for windows 7 pro?? or is there any other models for around that price i should consider?
HP COMPAQ 6300 PRO SFF Core i3 3220 @ 3.30GHz 8GB 500GB DVD-RW WIN8.1 Pro 64 BIT | eBay
