The case has nothing to do with cameras, but may be I can get help here.
I have downloaded a lot of films at home to my satelit box vu+ duo saved in its harddrive. I use Filezilla and transfered them to a extern harddrive which I brought with me to my cottage. There I have the same setup - a satelit box vu+ duo and transfer the already saved films from the extern harddrive to the box.
The extern harddrive is a Passport ultra with usb3.
I have wifi connection between my laptop and my extern harddrive to the vu+ duo box and find that the filezilla transfer at my cottage reach 1,2 MB per second. This is far lower than I expect. If I had a cable (RJ45) it would be 40-50 times higher.
My laptop have SSD drives and I tried to move the films over to a SSD and transfer from it to the vu+ duo box and got suprised when the transfer reach - exact 1,2 MB per second also now.
What can be wrong and I hope for suggestions to speed up the transfers. Today with almost one hour per film it is not acceptable.
In my asus 68u router I have checked the capasity of the wifi dongle in the vux duo Box and can see that the Tx rate (Mips) varies from 20 to 65 and the Rx rate (Mips) is about 6,5. This is greek to me, but someone might know. The laptop has 144,4 in both. But in the wlan status in the vu+duo box the bitrate is 144,4 Mb/s and the signalstrengh 90/100 and link quality 100/100. The problem should not be there.
I can add that no other connections were alive than the laptop and the vu+ duo Box.
