Im thinking about picking up a Bosch OD850 PIR and setting it up with a Sealevel 120e using Blue Iris. I've tried looking for some sort of guide on how to wire this up but i haven't been able to figure it out yet.
The Sealevel I'm looking at is below. It has connections for NC C NO which matches what the PIR has. So I assume its just a straight connection to these three terminals. But how do I power the PIR itself? There is a + - terminal but I don't see that on the Sealevel 120e? Do I need to power the PIR separately? If so what would be the best way to do this?
www.sealevel.com
Ethernet to 4 Optically Isolated Inputs / 4 Form C Relay Outputs Digital Interface Adapter - Sealevel
Control and monitor four optically isolated inputs and four high-current Form C relay outputs via Ethernet connection with Sealevel's eI/O-120E digital I/O module.
www.sealevel.com
