happyinbhc
Hey MikeHello BHC,
Sorry but I never used the audio out capability.
However thinking back forty five years to when I used to play with audio amplifiers these are the possibilities that come to mind for the buzzing issue :
- your power supply may be the cause. Try a different one.
- you are using a fairly sensitive amplifier with unscreened/unshielded wires from your camera. Try screened/shielded audio cable. Ebay or an electronics shop will sell this
- an earth/ground loop. Google for some articles on how to fix this.
The echoing sounds like a feedback loop. This is caused when the microphone you are speaking into picks up your amplified voice from the speaker and amplifies it again. This process repeats and results in an unholy cacophony of screeching noise. The solution is to place the speaker well away from the microphone.
Good luck.
To let you know the process, this speaker was an old computer speaker (harmon kardon). I tested the speaker before this project & no buzz. I think what I am going to do is try your suggestion & put a mono amplifier inline from the camera then out to the speaker. I will use shielded cable from the camera to the amp then from the amp to the speaker. I found an amp that wont break the bank if you want to have a look copy & paste this address; "Low Voltage Mono Audio Amplifier Board NJM386D LM386 - Ideal for Battery Operation" from www.parts-express.com!
Thanks for your input, I still find it hard to believe your thread was the only one I could find with the best explanation of possibly how to solve this
Mike
