You get it down to pigeon size movement but still get alarmed for bugs?that answer was correct. although I don´t believe everyone want that one =D ...
Do it the trial and error way, with expert setting if you got and start with oversensitive and work your way backwards to something that you want. I manage to get something like pigeonsize movement detection that I´m happy with, of course it will always trigger for shadows and branches or anything like that and small bugs close to the camera. but hey that is just a bonus =D.
I have alarm system. The problem with that is, the alarm goes off only AFTER someone broke in the house already. I want to be able to catch it before that happens. I want the cops to catch him in the act.dont use built in motion sensing for alarms outdoors, its only designed to save storage space when the image is static in such a dynamic environment.. using it for alerting or alarming is never going to get rid of false alarms without risking ignoring real alarms.
you need real alarm system that does not ever false to augment a video system.. using a video system in lieu of a real alarm system is really crappy at best.
I see, so only when the bug is very close to your camera you get the alert. What % did you set it to?Well if a small bug is on the lens or really close to it. It shows up as a mammoth try to put your face 2cm from your phone and make a picture BIG FACE
Sent from my A0001 using Tapatalk
Thanks. I will try 60% tonight and see what comes outI got one big area so got percentage down to about 5 and sensitivity to around 60. But this is totally individually depending on what size of area you choose to monitor (if I got it right )
