- Sep 16, 2014
- 480
- 119
I have a bunch of typical outside lights attached to my house. I leave these on all the time by the garage. I have no motion detector light, nor desire to install one. The problem with these lights--like most lights--is that most of their light is completely wasted shooting at the ground, the sides, the back, etc. I want to direct their light more aggressively to the driveway.
I've looked up reflective materials so that I can put a reflective backer into the square glass boxes (like a light house uses or a flash light, or even any halogen flood light), but can't find anything good and cheap with mirror-like qualities.
This would be awesome: http://electrictreehouse.com/ecobulb-directional-led-light/ if it were readily available. I can't seem to find a darn thing online about this, even with people rigging something up themselves.
This would work great except it's kind of a stand alone unit and I can't think of a way to properly fit it into the housing, particularly since the light has an existing socket. http://www.amazon.com/Woods-0151-8-...qid=1414966609&sr=8-1&keywords=bulb+reflector
Another option is a reflector light bulb like you may have in a bathroom, for example, but on an extender neck from amazon. However, I don't think I could get it to fit properly. The stand alone reflector in the back of the housing would be ideal.
