How to tell if it’s legit international version?
mark4312
Apr 11, 2018
22
3
I’m seeing things like this:
Dahua 4MP Mini Dome POE IP Camera IPC-HDW4431C-A ,Fixed Lens 2.8mm IP67,IR 50m Day and Night ,ONVIF, International Version https://www.amazon.com/dp/B076MRC9X7/ref=cm_sw_r_cp_api_9.HDBbVKTW5S8
Seems like a good deal. What’s the likelihood that this is one of the “good” ones at such a low price?
it is not...that model is not...firmware is not upgradable also points to hacked...avoid 4mp dahua if low light/night vision is important.
What would I specifically look for to tell?
the model is not found on the dahua international site and as i said, firmware is NOT upgradable,...firmware is always upgradable on international models. if the price is too good to be true there is a reason.
It does not support upgrading firmware. You are asking for trouble.
Buy the camera from Andy, You may spend more but you have support.
You get what you pay for.
I got to type faster !!!
Another tip is the price. Under $100 it's likely a chinese market camera.
