Hi,
I must be missing something obvious, Is there a ways to see or force the video source to be either rtsp 554 or onvif 8999. I had to find protocols & it lists both in the boxes on the right. I am not sure what it is using?
I have a lefek camera that is messing about, If you disconnect streaming at anytime after between 10 minutes & several hours it won't allow re-connect (up to this point you can reconnect fine). Can view throughout with browser control & if the stream is not broken, it seem to hold even if the other forms of view won't reconnect (barring the www which works always). BI is actually best at holding the stream.
VLC (Vlan) on 554 seems to disconnect by itself sometimes & then won't reconnect if the camera has failed i.e. while camera a OK it will reconnect.
My android app's do the same, won't reconnect & sometimes drop by themselves.
I only mention in case someone has any ideas, I am in contact with support & suspect firmware (is new, can use older)
A camera restart & it works fine again for 10min to several hours. I guess a bug but tryign to get round & wondered if just at some point if different users are trying to access using different protols it just breaks. This would have to be some set of circumstances anyway as does work mostly with several viewers on at once.
However I am just trying to see if using two different types rstp on 554 & onvif 8999 at same time or overlapping has anything to do with it but don't know what BI is using.
I have my android app on 8999. I will leave VLC off at moment but seems that can only use 554 anway.
"C:\Program Files\VideoLAN\VLC\vlc.exe" rtsp://user
[email protected]:554/1/h264major
THanks I/a
THanks I/a
