http://username:password@Camera-IP/cgi-bin/magicBox.cgi?action=getSystemInfo
Not on mine. It seems Amcrest has it but Dahua not on the cameras I've checked.On mine it's under information--> version--> Device type.
deviceType=IPC
hardwareVersion=1.00
processor=AX620D
serialNumber=9E09E25nunya
updateSerial=IPC-HFW5442E-ZE-0832
updateSerialCloudUpgrade=IPC-HFW5442E-ZE-0832deviceType=IPC-B54IR-Z4E-S3
processor=AX620D
serialNumber=9K0D7ACnunya
updateSerial=IPC-HFW5442E-ZE-0832So did mine but a subsequent update brought it back.One of my camera's "deviceType" got whacked in a firmware update
Thank you!! My camera model isn't written anywhere in the GUI and this worked+1^^.
But IF you're feeling fancy, issue the following HTTP command with a browser and you'll get YOUR response; mine is at the bottom:
Code:http://username:password@Camera-IP/cgi-bin/magicBox.cgi?action=getSystemInfo
appAutoStart=true
deviceType=IPC-HDW5442TM-AS
processor=HI3516DV300
serialNumber=????????????
updateSerial=IPC-HDW5442TP-AS
Too much code!Why don't they just write the model number in the GUI![]()
