I've got a Hikvision DS-2CD2132F-IS running 5.3.0, and I got it recording video to the internal SD card. It worked OK until the card filled up the first time. After that, more video is recorded but almost every clip has a gap of a second or more, I assume due to timeouts with the SD card erasing old files and/or having memory fragmentation issues(?) Anyway I want to try using NFS instead. I removed the internal SD card to force the device to use the NFS share, because there didn't seem to be a way to select one or the other in the iVMS-4200 storage screen.
I have a NFS share on a Linux box on my network. Using iVMS-4200 iin Device management/Remote Config/Storage/NAS I see my Server IP and File Path shown, and clicking the "test" icon results in "Testing succeeded". Under Storage/General I see the disk shown with total capacity (about 1 TB), Free Space: 0 MB and Status: Unformatted. Selecting the disk and doing "Format" takes about 20 minutes and then shows "HDD formatting succeeded". If I login to the Linux box hosting the NFS share I see it has created folders 'datadir0', 'datadir1',... each holding a lot of files hiv00000.mp4, hiv00001.mp4 etc. It appears to be good to go.
BUT, if I click onto another screen like "Main View", and then go back to "Device Management" and Storage/General, the disk is back to Unformatted and 0 free space. No video ever gets saved. I have rebooted the device, and so far have reformatted the disk 4 separate times. I also tried doing this through the MSIE web interface instead of the iVMS-4200 app, but still no joy. How do I get NFS set up correctly?
