How to set max fps on each camera?
Pentagano
Getting comfortable
Dec 11, 2020
671
301
Uruguay
How can I set the fps per cam and set it fixed? I see under VIDEO Max.rate but it keeps reverting back to a higher level after saving it.
Thanks
Are you able to access that camera through a web browser? That is where this change needs to be made.
Finally what a pain. Had to modify the config file in program files to open access to advanced settings!
Hello, Can you tell me which file to modify to see all the settings ?
Also is there any way to see the advance options for the cameras which are connected to the NVR. I can see the camera options only for those camera which are connected to my router and not to the ezviz NVR.
In NVR, look at cam status/IP address page, see if there is a browser icon, such as a big blue "e", to the far right of an online cam. Click on that icon to open cam's embedded webGUI.
In cam's embedded webGUI, look in cam's setup or "settings" for "video" settings.
Reactions: gwminor48
Thank you @TonyR , but my ezviz C3WN model doesnot seem to have any web GUI.
Same is try to the NVR as well.
The NVR as #80 open but which redirects to a index.asp with following error message
  • Sad
Reactions: TonyR
