HI
I am trying to eliminate missing alerts by ensuring every frame of motion is sent to CPAI for analysis. (note I have a powerful PC so CPU overhead is no issue).
The problem;
BI detects motion, and sends the images to CPAI. CPAI then analyses X no of frames depending on the number of real-time images configured and the millisecond time interval.
In some circumstances, CPAI fails to make a detection because the object wasn't clear enough from the frames analysed. The motion continues, however CPAI doesn't get any further images until the trigger ends and is restarted and hence the alert is lost.
My solution (which appears unreliable)
Configure Break-time as;
End trigger unless re-triggered within 5 secs
Maximum trigger/alert duration 5 secs
Configure the AI with +10 real-time images 500ms apart and set the "to cancel" as something such as a bear (we don't get bears in the UK)
So what I think should happen hear is that for the 5 seconds the alert is triggered, CPAI analyses an image every 500ms. As soon as the 5 seconds are up, BI either creates a new trigger (if motion is on-going) and the process is repeated or the trigger ends.
Is my logic correct, or have I misunderstood how the break-time settings work ?
The problem;
