We have 16 Hikvision cameras connected to a DS-7716 NVR(POE). The NVR had to be replaced but the pw's are not known. If I connect them one at a time to another switch, SADP can be used to get the xml file, send it to HIKVision for them to create a new xml file, and finally use SADP again to reset the pw. This is time consuming. Is there a way to connect a laptop to the nvr and sownload the xml files from there.
Thanks
Mike
Thanks
Mike
