I want to install a Hikvision camera against a wall with no junction box, since i simply need to run the cable from the outside wall to the inside, then plug it in. But i want to make sure that no water can get behind my mounting bracket and leak inside my wall. What is the proper method of making a seal for this purpose? Should i put some sort of putty or sealant on the hole, or should i seal around the edge of the mounting bracket? I was looking at something like this, but im not sure if it's proper to use it on stucco. http://www.amazon.com/Dicor-BT-1834...B4JS/ref=sr_1_1?ie=UTF8&qid=1456714422&sr=8-1
