One of the small problems with vBulletin Board is that its search function converts its search.php querystrings into a "search id" which ruins the search hyperlink when you paste the search results URL into a topic post, as shown below...
https://www.ipcamtalk.com/search.php?searchid=1123361
(When a user clicks on the above URL, "Sorry - no matches. Please try some different terms." is returned)
It may be useful to some members that this problem can be overcome by using the syntax method shown below..
More on this at...
http://www.vbulletin.com/forum/foru...110659-how-to-submit-a-search-through-the-url
Here are two (2) real world IpCamTalk examples...
Example 1:
HTH
You can submit a search to vBulletin with a URL, just like you can with the search form. The basic URL is:
Where searchword is the word for which you are searching.
Here is a list of the extra search parameters you can add to the URL. When you add a search parameter to the URL you need to add this to the end of the URL:&variable_name=valueSearch field: Search by Key Word
Variable name: titleonly
Values:
- 0 = Search Entire Posts
- 1 = Search Titles Only
Example 1:
- Search for the term: pinout
- Search topic titles only
- search.php?do=process&titleonly=1&query=pinout
- https://www.ipcamtalk.com/search.php?do=process&titleonly=1&query=pinout
- Search entire topic post
- search.php?do=process&titleonly=0&query=pinout
- https://www.ipcamtalk.com/search.php?do=process&titleonly=0&query=pinout
HTH
