How to pick out the best location to mount a camera?
rufunky
Pulling my weight
Dec 2, 2015
707
248
I'm trying to figure out the best location to mount this camera. What points should I base the location on?
- Best view of most likely place the intruder will go? ( facing down the hall where bedrooms are)
- Best view of most likely point of entry? ( facing back door and rear window )
- Cover as much area as possible maybe not as great of views? ( ceiling )
What other points should I consider??
I attached a picture of the area. Behind me is the stairs leading down to the foyer and again down to the basement ( also very likely entry point )
