how can i mount securely without using screws? is there an epoxy i can use to last at least 6 years?
This wall feels like tile or porcelain, if i screw in, what bits should I use? I only need to drill in maybe 1.5 inches deep to mount the camera's wall bracket.
the dome camera along with the wall bracket such as this will weigh about 2.5 lbs. https://www.amazon.com/PC110-DS-1272ZJ-110-Bracket-Hikvision-DS-2CD2142FWD-I/dp/B01C7RAIWI/
