*edit* This proposed method for figuring the sensor may not be accurate - see post #6 and later.
It's looking like Huisun are not necessarily programming correct info in the sensor line of config_hw.ini
But there may be another similar way - keep reading!
This is aimed at helping out over the uncertainty of the
"What sensor is in my Mini PTZ V2' and will it brick if I upgrade with the new firmware?"
quandary.
We know that following the shortage of IMX322 sensors following the Japanese earthquake, Huisun manufactured some Mini PTZ V2 with the IMX122 sensor.
We also know from posts on here that some V2s with the other sensor were bricked when updating with some new firmware.
And it seems that the ordering / delivery timing isn't a reliable way to determine what sensor may be installed.
So this post is aimed at gathering enough info from members that maybe a sticky can be created and maintained about what works with what and what doesn't.
And to protect against any future accidents - it would be good to have a recovery backup.
So how can I find out what sensor is in my Mini PZT V2? @pozzello has already posted about this, but to recap here is how I believe it's possible:
With your favourite telnet client (PuTTY or Linux or Windows telnet) start a telnet session to port 3232 on your Mini PTZ V2.
Rather than expose Huisun's not-very-well-protected root password, those interested can PM me.
We do want to keep Huisun on-side, after all, we're not aiming to enable paid-for locked features, just aiming to make best use of the camera.
This is the /home/config area.
In there are various types of files - those related to user-defined configuration settings, those related to default values, those relating to the camera hardware, written during manufacturing and holding items such as sensor bad pixel map, serial number, MAC address, model code etc - and the sensor installed.
The file of interest for the sensor is config_hw.ini
Check out the value in the line marked 'sensor'. In this case it's imx122
Remembering that the camera I'm connected to was @pozzello 's, which was bricked by a firmware update, and recovered, the observant among you may ask 'Why does it say imx122?'
Good question.
The answer is that the camera was recovered by applying a copy of mtdblock4 that @pozzello provided from his working camera. So this one is now a clone. @pozzello - this implies that the camera you grabbed mtdblock4 from has an imx122 sensor. Do you agree?
And that the bricked one was purchased in a time frame that covered the use of the imx122.
It will be of interest if others could do this check and we can reach a concensus that it works and is vaid.
Now a word about backups - and not just your configuration backups -
OK - so in case I brick the camera in future, how can I back up the flash contents for possible recovery?
That's pretty straightforward. With telnet access, the entire flash storage can be dumped as a backup by taking copies of mtdblock0-4
It's not necessary to have an SMB/CIFS or NFS share on your network, this can conveniently be done using tftp to send the files to a tftp server.
For a Windows PC, an old but good tftp server is the Jounin one here : http://www.jounin.net/tftpd32.html
Here is a session transcript of how to extract the mtdblocks from the camera.
We are using /tmp as the temporary area as it's in RAM and there should be enough space for the 16MB extract.
If there isn't enough space, mounting an NFS share would eliminate that problem.
quandary.
Code:
alastair@PC-I5 ~ $ telnet 192.168.1.131 3232
Trying 192.168.1.131...
Connected to 192.168.1.131.
Escape character is '^]'.
Ambarella login: root
Password:
# cd /home/config
# ls -al
total 532
drwxr-xr-x 4 root root 0 Jul 23 17:04 .
drwxr-xr-x 4 root root 0 Jul 23 02:42 ..
-rwsr-sr-t 1 root root 276480 Apr 7 13:17 badpixel_1080P.bin
-rwxr--r-- 1 root root 7359 Jun 25 2015 boa.conf
-rwxrw-r-- 1 root root 409 Oct 14 2015 capability
-rw-r--r-- 1 root root 1641 Jan 8 1970 config_hw.ini
-rw-r--r-- 1 root root 17129 Jul 23 17:04 config_media.ini
-rwxrw-r-- 1 root root 15904 Mar 1 17:07 config_media_130w.ini
-rwxrw-r-- 1 root root 15816 Mar 1 17:07 config_media_200w.ini
-rwxrw-r-- 1 root root 15811 Mar 1 17:07 config_media_ov4689_200w.ini
-rwxrw-r-- 1 root root 15804 Mar 1 17:07 config_media_ov4689_400w.ini
-rw-r--r-- 1 root root 2760 Jul 20 23:52 config_net.ini
-rw-r--r-- 1 root root 18489 Jan 1 1970 config_onvif.ini
-rw-r--r-- 1 root root 99 Apr 7 13:15 config_strange.ini
-rw-r--r-- 1 root root 99 Jul 23 03:00 config_time.ini
drwxr-xr-x 2 root root 0 Jan 1 1970 default
-rw------- 1 root root 101008 Jul 23 18:03 dome_setting.bin
-rwxrwxr-x 1 root root 37168 Mar 3 18:31 hwconf_server
-rwxrw-r-- 1 root root 1775 Oct 19 2015 ipnc.pem
-rw-r--r-- 1 root root 3072 Jun 20 14:59 ptz_preset_value.bin
-rw------- 1 root root 6528 Jan 1 1970 ptz_sequence_value.bin
-rwxrw-r-- 1 root root 134 Oct 19 2015 stunnel.conf
-rwxrw-r-- 1 root root 1050 Jan 7 2016 tinyproxy.conf
drwxrwxr-x 2 root root 0 Mar 3 18:31 upgrade
# cat config_hw.ini
;fixed feature
[mac]
macaddr = 58:04:CB:10:C2:D3
checkcode = 9689d10aa375fca039eda9414ca5596fcd0b652b
[product]
factoryid = 10C2D35702515B63CD
model =
inner_model = PCS022C0010AIDAD0A0000
[watchdog]
watchdog = 5
[hardware]
videoin = 1
videoout = 0
audioin = 0
audioout = 0
alarmin = 0
alarmout = 0
comnum = 0
multicam = 0
rotate = 0
peertype = 2001
alarmsync = 1
rs485 = 1
ptzctrl = 1
sensor = imx122
lens = 3001 ;XXYY XX(zoom) YY(index) 3000 3001 2000 3001 1000 1001 300 301 100 101
[focus]
type = 0 ;0 - iris + focus , 1 - only focus , 2 - nothing
zoomlist = 10,40,80,120,160,0,0,0,0,0,0,0,0,0,0,0;size must be 16,0 means invalid.
Good question.
Code:
Password:
# df
Filesystem Size Used Available Use% Mounted on
/dev/root 13.9M 13.1M 896.0K 94% /
devtmpfs 60.3M 0 60.3M 0% /dev
tmpfs 60.4M 4.0K 60.4M 0% /tmp
tmpfs 60.4M 0 60.4M 0% /dev/shm
tmpfs 60.4M 60.0K 60.3M 0% /run
none 60.4M 10.2M 50.2M 17% /ipnc
none 4.0M 0 4.0M 0% /ipnc/snapshot
none 2.0M 20.0K 2.0M 1% /ipnc/log
none 5.0M 0 5.0M 0% /ipnc/ringbuf
# dd if=/dev/mtdblock0 of=/tmp/mtdblock0
128+0 records in
128+0 records out
65536 bytes (64.0KB) copied, 0.016249 seconds, 3.8MB/s
# dd if=/dev/mtdblock1 of=/tmp/mtdblock1
384+0 records in
384+0 records out
196608 bytes (192.0KB) copied, 0.054247 seconds, 3.5MB/s
# dd if=/dev/mtdblock2 of=/tmp/mtdblock2
128+0 records in
128+0 records out
65536 bytes (64.0KB) copied, 0.015964 seconds, 3.9MB/s
# dd if=/dev/mtdblock3 of=/tmp/mtdblock3
3456+0 records in
3456+0 records out
1769472 bytes (1.7MB) copied, 0.488210 seconds, 3.5MB/s
# cd /tmp
# ls -al
total 2052
drwxrwxrwt 2 root root 140 Jul 23 23:52 .
drwxr-xr-x 20 root root 0 Jan 1 1970 ..
-rw-r--r-- 1 root root 65536 Jul 23 23:51 mtdblock0
-rw-r--r-- 1 root root 196608 Jul 23 23:51 mtdblock1
-rw-r--r-- 1 root root 65536 Jul 23 23:51 mtdblock2
-rw-r--r-- 1 root root 1769472 Jul 23 23:52 mtdblock3
-rw-r--r-- 1 root root 23 Jul 23 23:49 resolv.conf
# tftp -p -l mtdblock0 192.168.1.21
mtdblock0 100% |*******************************| 65536 0:00:00 ETA
# tftp -p -l mtdblock1 192.168.1.21
mtdblock1 100% |*******************************| 192k 0:00:00 ETA
# tftp -p -l mtdblock2 192.168.1.21
mtdblock2 100% |*******************************| 65536 0:00:00 ETA
# tftp -p -l mtdblock3 192.168.1.21
mtdblock3 100% |*******************************| 1728k 0:00:00 ETA
# rm mtdblock*
# dd if=/dev/mtdblock4 of=/tmp/mtdblock4
28544+0 records in
28544+0 records out
14614528 bytes (13.9MB) copied, 4.074778 seconds, 3.4MB/s
# tftp -p -l mtdblock4 192.168.1.21
mtdblock4 100% |*******************************| 14272k 0:00:00 ETA
# rm mtdblock*
# ls -al
total 4
drwxrwxrwt 2 root root 60 Jul 23 23:53 .
# echo "that was easy!"
that was easy!
