I have been researching outdoor cameras and installation for PoE for awhile now and am a bit overwhelmed. Terms like PoE switch, injectors, and powerline adapters, junction boxes, nvr are circling around in my head to the point that I don't feel like I know anymore now than I did when I first started.
Here's my situation. I would like to buy four POE outdoor cameras for the four sides of my house. The problem is that my house is basically a ranch style house composed of three different sections. Of course, all of the sections are connected, but the design makes the attic area appear disconnected. There's the east section with a garage and attic space above it; the west section with attic access (router is located in a room in this section - it's also where NVR would go); finally, the middle section - which is main living area that has a cathedral ceiling with no attic space.
I don't think I will have any problem getting the ethernet into the west side of the house, but how do I get it from the east side over to the router/nvr located on the west side? North and south would also be a bit difficult.
A couple other items to note: Would be difficult to run the cable outside along the soffit, not impossible, but very difficult. Basement where the modem is located, has a finished ceiling in all but two rooms. I do have CAT 5 ran from the modem to the rooms in the basement and might be able to get the east side ethernet to one of those, but I'm not even sure that is beneficial in any way?
I'm going to apologize upfront for my limited understanding of some of the terminology that I've seen here and on other sites. I'm willing to learn, but if you all can have a bit of patience with me in that process, I'd appreciate it. Thanks in advance.
