How to I get video clips from my Dahua NVR?
walkjp1
Oct 5, 2016
121
42
Philippines
I can pull up the clip on NVR. But cannot get it to cut or clip it. Not connected to a computer. Just want to save to a flash drive.
Any help please.
If there is no connection to a computer then you can only save a video via the NVR's HDMI WebGUI. When playing back, use the scissors at the bottom to mark the recording that should be saved and then use the floppy disk icon on the right to save.
Then the file can be saved as a *.dav or *.mp4 file on a USB drive. Although I have never tested this by myself.:)
Reactions: mat200 and walkjp1
Thank you,
Actually, that is what I was trying to do. But could not make it work. Andy helped me find out to do it.
In NVR right click.. main menu .. select back up... Select camera and set time . Change to mpg then export mp4
Thank you,
need download converter dav to mpeg
