alastairstevenson
Staff member
I think that varies with the camera brand / firmware. Hikvision aren't too bad.Any reason I should be concerned about the setup?
It's as much about what can be done by a bad actor via the Linux device that's inside your private network as it is about seeing what the camera is seeing.My Cameras do not cover any sensitive or indoor area's.
You might find it instructive to temporarily create a WAN block rule with logging for an individual camera IP address just to see what if anything gets attempted.
edit Sorry - a LAN block rule. Though that may pick up the redirected traffic from the static route if the source device doesn't do the redirect itself.
I have a couple of Chinese cameras that 'beacon' a few cryptic bytes on a specific port to a couple of Chinese IP addresses every few minutes.
It's probably the manufacturer trying to judge the installed base, but it gets blocked anyway.
