How do you find out what a device's "deviceid" is for BI? I have 2 iphones and 2 ipads registered to the server and I only want to have a push go out to one device. Is there a way to tell which device is which? I looked in the help first and the section on this was very brief. There was a graphic in the help file that showed a description in the "Name" field, but on mine it just shows "iPad" or "iPhone" and I can't see where I can change that. Does anyone know if I can label each one after I determine which is which?
