How to factory reset LTS CMIP3042W Turret
105437
BIT Beta Team
Jun 8, 2015
2,196
1,085
I have 3 of these to sell and I'd like to factory reset them. I have the NVMS7000 app but the factory reset command there doesn't reset the settings. Thanks
I can't remember the Hikvision equivalent model number on this but I think there is a small button on the rectangular part of the cable (the ethernet plug). It seems you have to depress the button while removing and then powering back up. Sorry if my memory is faulty but see if it has that small button on the cable.
Reactions: 105437
same as hikvision 4mp turret. download the firmware and tftp it into the cameras. it will erase all the setting.
