Hi,
I am mainly a Mac user, so please understand, I know just enough to get myself into trouble on a PC.
I have two cameras on my network that were set up without motion detection enabled. They are both TP cameras I purchased from a well known online retailer based in Florida. They set this equipment up via remote support and later I discovered that motion detection was not enabled. My old windows vista computer has since died and I was advised by this place to buy a netbook or tablet running some flavor of windows 7 or 8 to make changes. So I found what I thought was good deal and bought a windows tablet running 8.1. I though I could log on and make changes to the cameras. However I am finding out this is easier said then done on a tablet with no Ethernet or usb ports.
I was able to log on wirelessly to my NVR, no problem with my tablet after enabling ActiveX and listing the url of the NVR in compatibility view. But my cameras, plugged into the NVR's built in POE switch have a different url scheme- 10.1.1.XXX. There are no ports on this tablet, so I can't use a wireless adapter. Can anyone suggest a way to connect to these cameras so I can enable motion detection?
thanks,
Tubac
thanks,
Tubac
