Hello,
Just got all my wire ran through the attic and cameras installed. All cameras but one is connected.
Here's what I've tried:
SOLVED:
Alright everyone, per recommendation above and even though I tested it, it was the camera side connection. I replaced the end and it now functions as expected.
I appreciate everyone's assistance here and it goes to show, you can't always trust a cable tester...
- Replaced end on one side, not the camera side
- Tested with a cable tester for pairing
- Tried a second camera on the same cable
- Tried different ports in the switch and on the NVR
- Traced the cable in the attic, no obvious outstanding kinks
- This is a ~110' run, so I'm trying to do everything I can to not repull it.
SOLVED:
