bob2701 Getting comfortable Jan 7, 2016 1,022 489 Jersey Shore Jan 30, 2020 #1 On my Ezviz DB1 which faces North faces are dark while the background is perfect. What to adjust to correct? Bob
looney2ns IPCT Contributor Sep 25, 2016 16,321 24,225 Evansville, In. USA Jan 31, 2020 #2 Most likely you can't, adjust it for face captures and don't worry about the background. If you need to see the street, you need another camera. Adjust the BLC if it has the option. Or you will need to provide more light on the person's face. Reactions: bob2701 and SouthernYankee
bob2701 Getting comfortable Jan 7, 2016 1,022 489 Jersey Shore Jan 31, 2020 #3 @looney2ns Yes it does have BLC and I have played with that. Wish there was a way to turn it on/off with sunrise/sunset. Thanks.
looney2ns IPCT Contributor Sep 25, 2016 16,321 24,225 Evansville, In. USA Feb 5, 2020 #4 bob2701 said: @looney2ns Yes it does have BLC and I have played with that. Wish there was a way to turn it on/off with sunrise/sunset. Thanks. Click to expand... YOu can, just setup a night and a day profile in the cam.
bob2701 Getting comfortable Jan 7, 2016 1,022 489 Jersey Shore Feb 5, 2020 #5 looney2ns said: YOu can, just setup a night and a day profile in the cam. Click to expand... Thanks Brad, I’ll take a look at that.
