- Jul 3, 2017
- 1
- 0
VR camera P2 - Guangzhou Juan Optical & Electronical Tech Joint Stock Co., Ltd.
no ONVIF
how to connect VR camera ,Blue Iris 3
thank you
what version of BI?Same issue here
I did found a snapshot url
Http://ip:80/snapshot.jpg
Which works dor several hours but then goes down.
I did some sniffing and found that the windows software connect also to port 80 with use of the bubble streaming protocol on
Http://ip/bubble/live?
However i Dont know howto doe this in blueiris. Any hinys?
Bart
if the camera does not support onvif you will need to find the rtsp stream TroubleshootingLatest version of BI
Verzonden vanaf mijn iPhone met Tapatalk
The best way to eliminate annoyances it to avoid cheap no name crap cameras...I tried to sniff the RTSP using wireshark with no luck as well. It’s very annoying
True , unfortunately I live in Egypt and these are the only models released here specially it’s a new type of cameras , ordering it online is not easy as well because of customers and security clearances.The best way to eliminate annoyances it to avoid cheap no name crap cameras...
