[TD="class: votecell"]
[/TD]
[TD="class: postcell"]Dear ipcamtalk community!
I have this problem with my Hikvision ds-7608 nvr: I would like to connect a remote camera to it (just to be clear: the camera is on a location, and the nvr is on another with another internet access). I did everything that i can think of to make it work. The nvr has internet access and it is correctly configured with a static ip. The camera also has a static ip and internet access, the ports are forwarded in the router and i also made a dyndns domain for it. I can successfully ping the camera domain from the nvr location. So i thought there wont be any problem with connecting the two, but that's not the case...
I plugged these informations into the nvr:
(34567 is the media port of the camera)
And i got this:
[/TD]
("IP-kamera kivétel" means IP-camera exception)What am i doing wrong?Thanks for your time!
Levente
