- May 23, 2016
- 55
- 3
Hello,
I have created a sketch to describe the current situation (Attached), hope it helps.
I bought seven IPC-HFW4431R-Z Dahua cameras. (number 1-7 in sketch)
I already have one SD59430U-HN PTZ Dahua camera. (number 8 in sketch)
Plan to buy another 5 cameras soon. (number 9-13 in sketch)
I have some cameras away from home (9-13) and I'm not sure how to connect them all to the network. There is one network cable that reaches the remote area as described in the sketch. I can't add more cables.
Do I need a dedicated POE switch for the remote area? How many do I need?
Which POE switch should I buy? It is a bit confusing because there are many of these with differences technical specifications. In addition to that some of them Chinese products at cheap prices and some products of well-known companies at more expensive prices.
I would be happy to receive any help in connecting the cameras to the network in the best and most stable way.
remot
Thanks
remot
Thanks
