Hi,
I had no luck in official Mobotix forums (How to properly configure ONVIF/RTSP on MOBOTIX v26B-6D?, their supporters seems no longer active since Jan of 2023), nor any help via their website contact form, so trying here...
Basically, there's two MOBOTIX v26B-6D cameras that we need to make stream H264 via RTSP in as bigger resolution as possible. Camera itself supports 6MP, but one camera streams (in it's default first onvif profile) FullHD, and other camera only in HD (720p), and I cannot find a way to change resolutions in cameras web interface.
"Admin Menu" has "Integration Protocols" section, but there's not much to change: . Tried restoring to factory of that section, tried resetting onvif profiles, but nothing helps.
Config dump shows "rtpserver.json" section, and I see declared "FullHD" or "HD" there for video encoders, but changing with text editro that and re-uploading config file still does not change resolutions.
Both cameras has latest FW version MX-V5.4.9.9-r1.
