M MacFun Getting the hang of it Aug 1, 2017 383 71 Houston, TX Aug 16, 2020 #1 I have a 5231 turret cam, and I see that it is set to PAL and I want to change it to NTSC. Can you help me change this? Thanks, R Attachments Screen Shot 2020-08-16 at 5.29.12 PM.png 82.6 KB · Views: 13
samplenhold IPCT+ Member Aug 8, 2018 8,535 30,354 Spring, Texas Aug 16, 2020 #2 Well you could just click the dropdown and select NTSC then save. But I do not know if this actually works since I have never done this. Asking a stupid question: Why do you want to do this? Are you using a CRT to view the cam?
M MacFun Getting the hang of it Aug 1, 2017 383 71 Houston, TX Aug 16, 2020 #3 samplenhold said: Well you could just click the dropdown and select NTSC then save. But I do not know if this actually works since I have never done this. Asking a stupid question: Why do you want to do this? Are you using a CRT to view the cam? Click to expand... It's a personal choice. As a broadcast production guy it gives me pleasure. Also, I recall Andy saying this could be changed. The dropdown shows no NTSC option.
biggen Known around here May 6, 2018 2,800 3,209 Aug 16, 2020 #4 As said, it doesn't matter unless its an OCD thing.... Reactions: samplenhold
D dahukvision n3wb Nov 22, 2017 16 18 Aug 16, 2020 #5 I believe it's a choice in the initial menu after a factory reset, alongside the password and other essential settings.
