Hello. This is my first post here. My goal is to add two automated license reader cameras to my existing system. I have a 14 camera system using a LTS LTN8716-P16 16 Channels Platinum NVR Network Video Recorder with LTS CMIP1142W-28 4MP IR Outdoor Turret IP Security Cameras.
LTS Platinum NVR
Security Cameras
Out lot is fairly wide with a bunch of trees out front. Is it ok to mount ALPR cameras onto trees vs using a pole? I'm thinking of using a band bracket.
Am I correct that these automated ALPR cams use POE? This means all I have to do is to run a pair of CAT6 cables to the cameras from the house right? I'm installing landscape lighting around our light anyway so this would be the ideal time to lay the cables.
After reading the WIKI, I'm still confused as to the software required. Would I use Blue Iris and then subscribe to OpenALPR or PlateRecognizer?
Is Blue Iris compatible with my existing NVR?
And can I add the ALPR cameras to my existing NVR since it has two open ports remaining?
Thanks in advance for your help. I'm very comfortable building and maintaining PCs but I'm very green when it comes to security cameras. It's about time I learned!
LTS Platinum NVR
Security Cameras
