Good Day,
Can you provide a recommendation on how I can achieve unlimited circular or loop recording with some Hikvision IP cameras I have. I'd like to be able to store about 2 years worth of video - once the media is full the system should then begin overwriting the oldest video. So set it and forget it.
It doesn't look like the Hikvision camera can natively do this. Is the solution then to pair it with a more sophisticated NVR. Can you provide a recommendation? I've investigated online a Hikvision brand NVR - I even read the manual but it is unclear if it supports circular overwrites (outside of using eSATA)
Thanks!
Thanks!
