Just found out how to access Chinese devices from iVMS-4200. It seems like Hikvision made a mistake while packaging iVMS-4200 Lite and enabled this functionality out of the box! Nevertheless, same applies to "full" iVMS-4200 version.
Step 1:
Open Setup.xml file, which is located in the iVMS-4200 installation folder with any text editor (eg. notepad)
Step 2:
Change <Value>0</Value> to <Value>1</Value> under <Translator>
Step 3:
Save file and enjoy
This works, by changing currently set language (English - 0) to (Chinese - 1), but since iVMS does not come with Chinese translation files, it falls back to English translation while still acting like Chinese version (allowing to connect to Chinese devices).
Tested with iVMS-4200 Lite (v1.0.0.4) and iVMS-4200 (v2.8.2.2)
Step 1:
Step 2:
Step 3:
Save file and enjoy
