How many watts do you think these cameras will actually use?
ingeborgdot
Pulling my weight
May 7, 2017
775
176
Scott City, KS
I'm trying to figure out for a PoE switch what these cameras will actually use and what size PoE switch I should get?
SD5A425XA-HNR PTZ
SD5A425GA-HNR PTZ
2 - IPC-T5442T-EZ
2 - IPC-T54IR-ZE-S3
So, a total of 6 cameras plus a Nano station and EAP. Thanks.
Most people have reported that with infrared going the PTZs are around 23 watts and the 5442s are around 11 watts.
But you want excess capacity, so that equals 90 watts, but you wouldn't want a 90watt switch - you would need like 120w or so.
You will need a POE+ switch for the PTZs.
I spent 33 bucks on Amazon and bought a meter. Then I checked with IR off, IR on, and IR on with PTZ moving on cams that I felt I needed to know. That worked for me...
Reactions: CCTVCam and mat200
