I just learned about ODM. Loaded and it shows all my IP cams: the live view and able to change settings WITHOUT my edited password.
Im alarmed because Im on a home network, but dont trust the other people.
- How is this possible?
- And what setting [per cam] turns this off? (Restrict feed and settings view to password only)
- If yes, I thought that Onvif was only the protocol for sending the video/settings feed to my NVR, and not an OPEN door for anyone on the network to see the feed/settings without entering the pass.
- In SmartPSS, I setup the [non Dahua] cams using Onvif protocol, to get them to work (so I thought the ONVIF checkmark/whatever was required to be on). But in [SmartPSS > camera channel setup], I entered the new pass for the NVR to see, thus I thought that access was password locked (and then viewing the feed/settings on the NVR was restricted behind a User pass). The cams no longer have the default pass, so how is ODM able to get into the settings/feed merely by being on the same network?
