- Jul 1, 2015
- 7
- 1
I'm looking to buy a Hikvision/Dahua surveillance setup with audio to record barking dogs and some reoccurring vandalism happening in our neighborhood and would like to know how effective Blue Iris would be in these situations? For motion activated recording in the instance of a car driving by would the motion activation take a certain time to activate to the point where you're not getting footage of the moving vehicle the instant it within viewing range? Would the same go for audio where say the sharp report of a dogs bark might initially start the recording but not actually capture the brief bark unless the barking continued for some time?
Is there a set amount of time where the recording would continue after triggered be either motion or audio such as a 10 second window before stopping to record? How exactly does the motion and audio activation work as iirc cameras with built in motion activated recording use infra red sensors to detect heat, how does Blue Iris work in this aspect? Can I expect reliable and accurate recordings for my purposes?
