- Aug 7, 2017
- 418
- 225
I've been trying to search on this and it is not clear.
My sister has Ring and I'm damn near positive none of them know how to set up port forwarding, let alone their router. So then how does the app on the phone know how to access the Ring/Nest cams?
A quick search reveals that Nest and Ring doesn't actually required inbound port forwarding. But it does talk to their servers. Somehow, using some method, they are able to establish a connection just by using outbound connection. So I'm assuming that Ring/Nest server is the authenticator. The iphone apps all connect to Ring/Nest servers, then it pairs up with their devices (matched by serial numbers), and then Nest/Ring "pulls" or forwards those feed coming outbound already, to the matched serial number user. Then, that's how they do it.
But then, that means that... Nest/Ring continuously has access to your feed 24/7.
Is my understanding correct?
