New to cctv, I'm currently on a Hikvision NVR route, how long remains to be seen. From initial trials I've experienced the constraints of a Hikvision system. There's limited flexibility to use other makes of cameras, there's a camera subnet, removing cameras from the configuration could be far better, next I suspect will be limited control over zones and alerts. A user seems to have to fit to a Hikvision system rather than being fully in control.
Instead how do you run your dedicated BI PC, where sited, a cameras display in every room perhaps, how do you receive BI alerts, and anything you think important I have missed out about the physical set up.
Current my Hikvision NVR is on the LAN, W10 iVMS handles the camera management, all cameras on a subnet, so too a network switch, switch feeds NVR and mains TP-Link. Any room TV in my house will be able to display the cctv cameras using Raspberry Pis. My Linux based PC's, wifi and wired Ethernet have VLC. The Hikvision NVR was cheap compared against a reasonably fast Intel CPU PC with BI, and probably more reliable 24/7, and using less power. The TP-Link works here, has two Ethernet sockets so at any mains outset can have LAN or subnet available. I'm already factoring in the flexibility to move the NVR away from the loft in hot weather, even here in the UK.
If I adopt a BI PC instead of the Hikvision NVR I'll need more information. Most of help here and on youtube focusses on how to use BI software.This is more a nuts and bolts question about running a BI based system.
