Just make sure you keep the twist right up to the connection. Like the way he has the bracket upside down. lol
Disagree with the comments saying use type B.I have preexisting Cat5 in my house that I need to terminate with RJ45 plugs. Do you use T568A or T568B standard for IP cameras or does it matter?
Thanks,
Derek
If you read the OP, no preexisting standard is mentioned. B should be used.Disagree with the comments saying use type B.
IMO, you should see what is already installed in your house and stick with that standard, wether A or B. The last thing you want is a mix of wiring standards in your house
