How do you get push notification image to come through on Android?
dannieboiz
Joined
May 13, 2015
Messages
491
Reaction score
71
At one point it was working fine but for awhile now I stop receiving pictures with my push notifications. I read posts about having to VPN or port forwarding etc but I can say that nothing's changed with my settings.
Does anyone have it working?
wittaj
Joined
Apr 28, 2019
Messages
25,515
Reaction score
49,779
Location
USA
Something changed.
What did you do before VPN or port forward?
dannieboiz
Joined
May 13, 2015
Messages
491
Reaction score
71
I've always port forward to access Blue Iris remotely and only recently setup open VPN to access my local network but never use it for BI, it is for something else. But even when I'm local I still don't get an image.
dannieboiz
Joined
May 13, 2015
Messages
491
Reaction score
71
I think I finally figured this out...
In the webserver tab, I unchecked Use an https port (stunnel)
one more step if that doesn't work is in the "remote, external access" instead of using your public IP put your domain name there and disable refresh external IP on startup.
dannieboiz
Joined
May 13, 2015
Messages
491
Reaction score
71
ISsue was not he settings altough that certainly was not intuitive and he help manual had ommisions as well that one had to find out by trial and error. Big probem is one needs to have the app open (connected) to get pop ups. Different than Ring and others where you can have the app closed.
This is incorrect... I have the app closed and still gets image.
fenderman
Staff member
Joined
Mar 9, 2014
Messages
36,910
Reaction score
21,308
Where would you get such an insane nutty idea?
looney2ns
Joined
Sep 25, 2016
Messages
15,716
Reaction score
23,062
Location
Evansville, In. USA
Nope you don't.
fenderman
Staff member
Joined
Mar 9, 2014
Messages
36,910
Reaction score
21,308
Thanks, but the app is CONNECTED right?
How would the app be connected if its closed?
For the 100th time. The app does not have to be open to get a push notification. If you want an image with the push then you need the app to have access to the blue iris server to get that image, DUH.
dannieboiz
Joined
May 13, 2015
Messages
491
Reaction score
71
Im not sure what youre asking. You mean like initially connected to the Blue Iris server? If so then yes, just the first time so BI knows where to send the alert.
If you mean connected by its active running, then no. I can restart the phone and never touch a thing and still get an alert just as any other alerts on the phone should. happened
Top
