Morpheus_FJ n3wb Sep 19, 2023 6 7 Vancouver, Canada Nov 10, 2023 #1 Bell Output is 700mA on the NEO 2023 , and 2 30 Watt siren are around 350mA to 1100ma each. Do I need to add an Extra Power Supply?
Mark_M Known around here Jul 2, 2019 1,114 1,564 Land down down under Nov 10, 2023 #2 Use a relay and power the relay's coil from the 'bell output' connection. Then wire a second power supply with the relay switched contacts and the sirens. I suggest a relay with opto-isolation and a back emf diode already soldered. Reactions: Starglow and TonyR
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,330 48,136 Alabama Nov 10, 2023 #3 +1^^. I like these, available in 5VDC, 12VDC (shown) and 24VDC, provides NO and NC relay contacts ==>> HiLetgo 12V 1 Channel Relay Module with Optocoupler Isolation Support High or Low Level Trigger As an Amazon Associate IPCamTalk earns from qualifying purchases. Reactions: Mark_M
