Hi folks.
I just recently discovered the world of iptv, and im in the fist steps of my setup.
Right now, im planning some places and getting some idea on how to start.
My biggest concern is, how the hell i can get some clear images with all the trees i have in my property.
I tinkered a bit with IPVM, bit i think that im more lost than any other thing, between ranges, angles, ppf...
Here I atached some pics from google earth, so you can see how many trees are.
Right now my plan is to get a first varifocal turret (looking for insight here too(2mp starlight 5231R-ZE as i read, but Andy showed that will be a good load of new cameras soon)), and setup a test rig, so i can figure which are the better focal lengh of each camera. But im lost about where i can start viewving the obvious right spots to place the camera. I have 20m STP cat5e to start.
A few questions i had right now.
-Is better to have 2 small poe switch (4-8 port) instead one bigger one?
-STP or UTP?
-Can I run 5e between camera and switch and cat6 only in the uplink to the computer? bottlenecks?
-can i run the poe switch directly from the computer (aditional nic), or is better to go throught a router.
-Is there any issue with branded nics (intel better than realtek...).
-I had automatic pir lights outside, will be any issue between them and the cameras? should i disconect/remove them?
Thanks you
-STP or UTP?
Thanks you
